Need some advice. I have a 12meter 24Vdc cable run…. Current 3Amps.
I require a 1.5mm cable 6 core for supplying led strip lights outside due to volt drop.
The cable will be passing through stud work with rock wool insulation fitted.
What 6 or 7core can I use in this install, are there regulations to what cable that can be used?
Was looking at NYM-J cable or will I get away with YY?
Cheers.
Glasgow
Multicore cable domestic question
Domestic Electrician Forum
Thread Tags
alfa20ad,
alfa20ad,
