Darkwood
Relating to an earlier discussion of using common multicore cable for multiple circuits ;; their isn't anything wrong with this as long as the insulation is rated to the highest voltage of all the circuits contained in the cable and that it is possible to locally isolate all circuits at one point, its slighty of track here from domestic but this is common in servo cables and machinery... as long as screening etc are taken into account..
A lot of motors run one multicore cable that house both the motor feed and other control based wiring like thermal trip or force fed fan.... again its not so common in installation wiring as it has no functional advantage usually.
I think the op or his 'Mate' who has said this is getting confused with generated Eddie currents when not running all the phases of say a 3 phase load through the same conduit set or glanding points in a metal plate - which can give way to high heat generation and overheating of cables
