J
jase
hey forum, does anybody know if you can get shaver sockets with multiple outlets instead of the bog standard 240/110?
A customer has asked cos he wants to charge 2 electric toothbrushes at the same time plus also use a shaver?
any ideas?, i have scoured the net but so far have only come up with a 240V shaver point by MK that is single gang sixe so could put 2 in a dual box but at £49 each bit pricey!!!!
tell the muppet to charge 1 toothbrush on mondays, the other on tuesdays, and unplug if he wants a shave on those days. next thing will be he wants LCD TV, MP3, sky box, phone charger , all in bathroom.
I think you will have problems finding a twin outlet shaver socket as electrical separation rules change once supplying more than one item of equipment.
However there are other one gang shaver sockets out there at better prices £11-£20
Compact 1G Shaver Socket - HS1M
Excel 1 Gang Dual Voltage Shaver Socket - QVS Electrical Supplies | Electrical Wholesaler
MK (ELECTRIC)|K700WHI|SHAVER SOCKET - SINGLE VOLT | CPC
This is the MK one from Neweys
Buy MK Electric Moulded Shaver Socket Outlet, Fused, Single Gang, 200-250V, 86mm x 86mm, White - K700WHI
my wifes toothbrush needs charging at most once a fortnight Shaver lasts a month on 1 charge so WHY would he want 3 outlets ffs tell him you are restricted in what you can fit Pillock clients do my nut in Hence im glad I dont do Domestic
multiple outlet shaver points??
jase,
mogga,
