Guest viewing is limited
Hi,
I thought Id just share what Im doing with everyone.
At present I have a 16th Edition Hager board, its full, its got 18 circuits in it, and a couple doubled up.
I purchased a plastic one 12 months ago to take 20 ways, and was just looking at changing it next week for the plastic one and back dating it.
But having 20 RCBO's in it, its going to be a pain in the --- to get it done and neat and not crammed in...
So....
I am going to order a Hager Invicta 3 8 way board so I can get 24 single phase ways in it, also leaves me loads of space and will not bling on the wall in the garage.
It will also leave a lot of space so that I can fit a surge protector at a later day, just need to by a single phase conversion kit and an incomer but it will look a million times better on the wall and 10 times easier to terminate everything.
The only thing that ill have to do is lengthen a load of the circuits, not all, but a chunk of them, and also extend the 25mm meter tails, I have to admit, im not a big fan of extending tails as I don't like a joint in them, but it will be impossible for me to draw new tails in as they go up the cavity and across and its a non starter. I think if I just double heat wrap them and crimp them well it should be fine.
Anyway, the Invicta board, at least it complies with Amd3.
Ill post photos up when I do it.
Its costing me quite a bit as ill need 20 RCBO's and the board, and kit etc, £650 in total!!
I would consider a 4 tier board (3 tier slotted cover) where you use the normal 3 tiers as you suggest but use the 4th for din rail mount connectors (Ideal if all cables entry is at top or bottom), this way all circuits L/N/E will terminate into the top extension rail and then you wire to your mcb's etc. You can even wire up the board at home then only have the connector bank to terminate.
Its metal underneath... surely that complies? The lid over the breakers doesn't need to be metal too does it?
I can't say as I had even thought about it.
The glazed doors are not actually glass but polycarbonate if I recall correctly. I'm sure they do a unglazed door though, although I think it has plastic parts to it.
So... why are you changing your board ?
The only reason i want to change it is because I want everything on RCBO's and its so full its ridiculous, we are also looking at having a big ish two storey extension and will probably run it on new circuits, so would like the extra space.
The Invicta boards are very nice, they look good and there is a lot of room in them which is why i want to use one.
This is one, this must comply to AMD3, its a metal board with metal front and metal door, with metal hinges.
bet you the schneider board is cheaper and you get hammer in RCBOs. lol. :54:
Hi,
I've got a nice shiny plastic one in my own place ( empty at the moment except for the MCB,s ). By the time I get around to installing it the 18th will have come and gone, that's the problem with a bad back have to take things a bit slower.
Regards.
I have a nice metal enclosure for sale that should solve all your AMD3 problems.
Handcrafted in Geordieland from recycled soup, beans & beer cans by Bread & Co. Tinsmiths & Chamberpot makers.
Very cheap to leccy forum members - only £249-99 and you can keep the change.
It's your house, it's under your supervision, I know it's not the point but notify it now with December 31st date, you can do what you like. everyone's a winner!
but as long as the job was designed pre=amd3...........
I wonder how long this can run for though. I'm sure some will have a plastic board in the cupboard with intentions to install for the past year, but when they eventually get round to it in 10 years, technically it was designed prior so should conform.
it got fat 'n'graad 'n' it graad t' an aafull size ....:dizzy2:
a bit like a geordie's heid! :mad2:
What surprises me here is UKsparks has no idea of the actual requirements of Am3 domestic CU's.
How long has this been coming??
Market Harborough
My Consumer Unit
uksparks,
uksparks,
