Need help with connectors crimping 4 turn signal
  1. I got a 2015 Toyota prius c. I ordered 2 pigtail connectors for the turn signal wires so I can connect it with the pigtail female connector of the bulb base. The dealer sold me only the bare connectors without the wires because those were the only ones he could order.
    Now I have this problem of soldering or... the harness wires into these bare pigtail male connectors so I can plug them into the female pigtail connector from the turn signal bulb base.
    Can someone tell me if it is possible?
    If not, can I just use separate regular electrical connectors to connect them one by one into the bulb female pigtail ?
    Attached Files:​
    #1
  2. ChapmanF
Is it only the 2 wires for the connection? You may want to try the auto parts store for just any connector male and female and replace it that way. Otherwise you should be able to remove the pins out of the old and I to the new part you received. look up dorman 91441.
