Guest viewing is limited
  1. I got a 2015 Toyota prius c. I ordered 2 pigtail connectors for the turn signal wires so I can connect it with the pigtail female connector of the bulb base. The dealer sold me only the bare connectors without the wires because those were the only ones he could order.
    Now I have this problem of soldering or... the harness wires into these bare pigtail male connectors so I can plug them into the female pigtail connector from the turn signal bulb base.
    Can someone tell me if it is possible?
    If not, can I just use separate regular electrical connectors to connect them one by one into the bulb female pigtail ?
    Attached Files:​
    #1
  2. ChapmanF
Is it only the 2 wires for the connection? You may want to try the auto parts store for just any connector male and female and replace it that way. Otherwise you should be able to remove the pins out of the old and I to the new part you received. look up dorman 91441.
Los Angeles, CA, USA
United States of America
Electrical Enthusiast (Unqualified Hobbyist etc)
Need help with connectors crimping 4 turn signal
USA Electrical Forum
Thread Tags
Tags Tags
help
CITROENfan1,
tshezz,
USA Electrical Advice
Welcome to the USA Electrical Forum at ElectriciansForums.net. The friendliest electrical forum online. General electrical questions and answers can be found in the electrical forum.
This is the main UK Electrical Forum at ElectriciansForums.net. Electrician Laws and Regulations related to Electrics and Electricals within the United Kingdom. Electrician talk, questions and answers can be found in our UK electrical forum.
