David.
morning chaps,
got a room that is now going to be used as a computer room. Approx 8-10 computer couple printers and maybe odds and ends.
Going to run dado trunking of which totals approx run of 11 meters.
Im after a bit advice my idea will be suitable Im thinking of....
running a 20A MCB submain in 2.5mm T&E from 3P+N DB to a new board in the computer room.
into 100A main switch
then have 2x 16A 30mA RCBO Type C
2.5mm T&E from each RCBO feeding 5 double sockets each with "Computer Socket" stuck on
run a seperate earth to ensure high integrity
im hoping this should minimise nuisance tripping and provide a local means to reset RCBO should it trip. The submain cable is going to be fed through the ceiling.
My background has been industrial/machine/panel wiring short spell house bashing so commercial setups i've never been in?
thank you
thank you
