in particular what code covers cables less than 50mm in a wall, is it c2 potentially dangerous???
No code for this in particular as long as it's in a safe zone. You would more likely be coding for no RCD protection for cables concealed in walls ≤ 50mm
I don't see what safe zones have to do with it, it's a Code 3, check page 15 of the ESC Guide that Des linked to above.
It was the mention of 'safe zone' that I queried, what did you mean?
Being a bit thick, when do the new codes come "in force"?
hi Jud sorry i meant less than 50mm with no RCD protection
