C
ChrisElectrical88
Those are gay seals.
This is my query. It's fine if there is no alternative but to get an isolation switch fitted, but am purely asking if there is any other method.
In answer to that then....... yes there is.
Hi all.
When upgrading a fuse box to a 17th ed. CU is it a legal requirement to get an isolation switch fitted, or can it be done live. Far from ideal I know, but the £90 price tag set by manweb puts a lot of customers off.
Thanks.
Do these other methods fall within the regulations? If so please feel free to expand.....
hi
if there electric is supplied be a electric supplier they contact them it takes a week, and its normally free , if its british gas its 49.99 or there about , i had a chat with western power this week and they are happy for someone to pull the fuse ,then i fit the isolater which are £30 to buy a 100 amp . its all great cutting fuses but if they turn up or the property owner is asked they will blame you . you need safe isolation so you can upgrade the tails to 25mm . follow the book you wont go wrong . i no loads of sparks doing it and there always looking over there shoulder . hope it helps kindest regards jason
well isnt 25mm and 16mm earth , current regs . and any seals you cut is against the law , as if we dont no already , ( 3 reasons we cut seal . safety of property . livestock . people ) then we notify the correct authority to reseal . and on about being on the phone for so long its not you who rings obviously its something you dont do . take no notice of who said just cut away because they are wrong if unsure ring yourself .this is the problem with sparkys out of date . sorry you are definatly wrong .
