Discuss New DB loaded with RCBOs in the UK Electrical Forum area at ElectriciansForums.net
Wish I was earning that on a board change I would've come in at about £550 If there was no bonding to do etc based on a days work.
In fairness if the pricing was agreed or never asked for then there isn't anything wrong with it. I certainly wouldn't criticise someone for charging good money for work. Unfortunately in many places it is hard to sustain fair (to the Electrician) charges.I agree total rip off I would say around £600 for materials with a little mark up so £1300 for 7 hours work around £185 an hour just a joke, £900 job in my eyes
Risteard is this your signature or has the forum dropped an advert in that looks like your endorsing?In fairness if the pricing was agreed or never asked for then there isn't anything wrong with it. I certainly wouldn't criticise someone for charging good money for work. Unfortunately in many places it is hard to sustain fair (to the Electrician) charges.
Test the installation first.
Well that is why you should test it first.I try to do some basic tests before quoting, but that in itself can cause problems...
Firstly, do we charge to test the installation, knowing that we may not get the work? If so, how long do we work for free?
Secondly, assuming that the IR tests are ok, what if there is a break in the ring on one or more circuits? I find this on nearly every board change).
Thirdly, when changing from an old rewireable to an RCD board, do we test all appliances which could have earth leakage?
Fourthly, do we check that there are no shared neutrals across lighting circuits?
Obviously, once we start testing circuits properly, we may find missing earths, dodgy connections, spurs off spurs, incorrectly-sized cables, missing enclosures, damaged accessories, and so on.
What you could do is say to the customer that when changing a CU the circuits your reconnecting has to be safe to do so. If you find something that's not safe there may be an additional cost to make it safe which will be discussed if a problem arises or the circuit cant be connected. To circumnavigate this you could have an EICR done for a small fee of £££ which will bring up any defects and if any are found this can be discussed and priced before you proceed with the change. If you have the CU change done within 2-3 days of the EICR I can offer you a discount of ££ amount as I have all the results of the dead tests from the EICR. This way you earn extra from doing the report having a chance to price defects without being under pressure and if the customer isn't willing to pay an additional cost to rectify any defects your still quids in from doing the report.I try to do some basic tests before quoting, but that in itself can cause problems...
In an ideal world this would work great.What you could do is say to the customer that when changing a CU the circuit your reconnecting has to be safe to do so. If you find something there may be an additional cost to make it safe which will be discussed if a problem arises or the circuit cant be connected. To circumnavigate this you could have an EICR done for a small fee of £££ which will bring up any defects and if any are found this can be discussed and priced before you proceed with the change. If you have the CU change done within 2-3 days of the EICR I can offer you a discount of ££ amount as I have all the results of the dead tests from the EICR.
Reply to New DB loaded with RCBOs in the UK Electrical Forum area at ElectriciansForums.net
