Discuss New Gadgets or tried and trusted methods in the UK Electrical Forum area at ElectriciansForums.net
S
Silver6003
Hi there so I'm Doing a Domestic Flat With a lot of Gu 10 led down lighters . bathroom ones being Ip44 and the rest fire rated . I've wired the lighting in conventional 3 plate wiring . So Feeds ,Switchline . Neutrals and pcp all at 1 light. Switch Line neutral and pcp looped in each room. Also both bedrooms I've run a feed cable to both wardrobes to operate wardrobe lights . So in some cases I've 1 ,2,3,4 and some cases 5 cables at lights . Of course 3 core to feed fan isolator for over run fans in 2 bathrooms . That's My scenario
So I'm a luddite in some ways .... If it works why break it Vibe . I've seen lots of new found products to connect them up Clix and wago with junction boxes etc . However My first thought was the tried and tested method of using 4-way junction boxes With 1.5mm2 heat resistant flex feeding each downlight .
I'm working on an hourly rate on this installation ( it was too complicated to put in a price already there's been alterations etc ) So time is not a factor
So Appreciate your comments. Even better, ideas if you have any
Thanks guys
I find that a wago box with a SL/N to each fitting works well. This means investing in some wago boxes and connectors, but the amount of time and effort saved more than makes up for it. I've learned that there's some things that I just don't "get"; buying the cheapest, rather than the best that you can afford, sticking with old methods with known drawbacks, rather than trying new stuff to get around the drawbacks. Each to their own, but I see investing in such malarkey saves a lot of effort in trying to get 5 cables terminated safely. neatly at a light fitting.
Too late now, but with downlights, always take feed to switch and then sw line & neutral to each light and loop in & out. Or perhaps Click flow CT102 for 3 cable loop in & out.
I've used numerous items over the years, all have their merits, hager coffin boxes- great but screw terminals still, click flow plugs, screw terminals again, but also less room for cable, and no cable grip, quickest I've used are the line products egg things along with wagos, and cheapest but just as effective are the greenbrook choc boxes from screwfix with wagos inside
I always like to have a good few Hager Ashley and plenty of Wagos in the van. Both would be my weapon of choice. Used a traditional 30A JB the other week for the first time in ages and find them fiddly by comparison.
Not keen on the purple/blue click flow connectors due to no cable grip as mentioned. For your particular job I would normally use Wagoboxes.
You can get the click flow connectors with cable restraint, its just that no wholesalers seem to stock them.
These just don't look up to the job, are they any good Guys.? I would just feel inclined to use the good ole JB. Space looks limited, guess it just fear of the unknown.
I hope they are Dave, as I have used loads over last few years! A lot of the newer sparks definately use them. I find them quicker than trad JBs to install.
If I was still contracting then I would be able to see for myself, alas don't think will. New products come on market some look really good must say.
I personally don't like the wagobox. It's clunky and awkward to use. They are ok as a fixed accessible connection box however. The smaller wagobox lite is better as it has a cable entry each end but is obviously smaller.
trusted method? neutrals in the switch box, joined by a wago. less monkeying on a ladder to connect it all up and no problems with modern lights.
Horrible things with limited space. The Line eggs are much better
Granted they can be a bit fiddly and the cord grips are naff. I always leave the CPCs longer than the live conductors and then connect them up last (at the top of the box) and I find that makes them more workable. Never used the Line gear, was going to order some a while back and never did due to the stock issue posted on here.
Are Line delivering properly again now?
The Wago box gets a vote from me. Granted gets a bit messy with more than four cables. But likewise, I haven't used a round JB in a while.
I love the push fit connectors, I like the hellerman tyton ones, but they are not easily available locally, then ideal splice line are very neat for through connections, the lever action ones are easy to use (and do not flick back on your fingers!) and the wago lighting (push fit and clamp action) are also handy.
Never used a wago box, but love the line JBs, the Line products website is now back up and running, I assume they just forgot to renew the website access.
Will be ordering more today to check all is OK.
Will you pop up a note in the line thread as an update ? I feel like ordering a boatload while the going is good.
Reply to New Gadgets or tried and trusted methods in the UK Electrical Forum area at ElectriciansForums.net
Hi, I'm looking to install a new bathroom extractor fan in my bathroom as I have a windowless bathroom and the current one I have installed in...
Hi all, Got an awkward bathroom fan installation in a downstairs flat, concrete ceilings and (some) walls. Bathroom is already fully tiled and...
Hi, looking for some ideas on this. I went to an address on Tuesday following a storm where property has been struck by lightning. When the...
