Discuss New Garage Supply Certs in the Electrical Forum area at ElectriciansForums.net
you already have one completed EIC for your original work , that cant be changed so put it to one side.
the rest of the planned work can be recorded on 1 extra EIC with 2 test schedules.
christ almighty.
Depends on if it has already been notified or not, often if I know there is additional work to do, with the CU change as a prelude, I will hold back the paperwork until the job is finished, although I will not hold it back for months and months on end.
Am i missing something here ???
What has notification got to do with how you write out your certs ?? they completely seperate issues.
And Murdoch you cant add to the original cert once its been signed and dated even if your test software allows you to do so.
I'm now getting lost here guys, looks like i'll be charging more to fill out Certs than for doing the actual job.
I was thinking of producing a new EIC for the installation of the sub main and adding a second SoTR for the garage. If it's wrong then i'll hold my hand up.
No, not really,
If the job has already been notified, then you have no choice but to issue another EIC, but this will include two sets of SoI's and two sets of SoTR's (although you may be able to use one SoI for the lot), as Biff said.
You need two sets of SoTR's as you have two different installs, with two different supply characteristics, if this makes sense.
Bloody difficult to word on a forum!
What has notification got to do with how you write out your certs ?? the completely seperate issues.
And Murdoch you cant add to the original cert once its been signed and dated even if you test software allows you to do so.
Because, if it has not gone through (notified yet), he can notify it all as one job, hence under One EIC, when you notify you have to put the description and extent of the work, this can all be included together.
The original Cert for replacing the CU has been signed off and notified.
I'll be able to produce a new EIC solely for the installation of the sub main. I will then add a second sheet of test results for the installed components in the garage from the second board.
If this isn't acceptable can you please explain why?
Sorry gents - you must be sick of this by now!
As an example Biff,
If I fit a new CU one week, and I know for definate there is a shower to fit the week after, then I will not finalise the paperwork or notify it until the Job is finished, this is common sense, it saves duplicate paperwork and two notifications and attendant fees.
Reply to New Garage Supply Certs in the Electrical Forum area at ElectriciansForums.net
