Discuss new here working in France in the The Welcome Forum area at ElectriciansForums.net
Hi all just joined,for some where to talk about all I see here, there are 2 kinds of problems here the French diy's and the English diy's anyone who can pick up a screwdriver can work on there own or any-ones electric installations, A good idea? just to make things more fun most of the older houses have a 3 phase supply.
I went to a house the other week and here you buy the supply by the kw so if the demand goes over that the whole installation trips, they had a 3 phase 30A per phase supply, when I got there they where only using one of the phases so when demand got to 30A it tripped, the other 2 phases had been left hanging outside the box without the ends even taped up, so if anyone had touched them they would have had a bit of a shock and if both at same time not good, guy that had did it say it a diy handyman said he did not understand 3 phase so did not know what to do with the other 2 phases! more tails to come
Welcome to the forum mate..
Welcome along Mon Ami, hope that's the correct spelling never did French at School,
Welcome to forum Ian,
Read your horror story with interest... If I've understood correctly, an unqualified "handyman" left two live mains cables unterminated outside a house... ? Shocking! :astonished:
Kind regards NB
thanks all for you welcome, another problem I found this year some-one had put the control box for the swimming pool on a 3 phase socket but had got the plug and socket the wrong way round so you had live pins when you pulled it out. When I checked it out they just used 1 phase but had not taken a earth to the pool or even put in a earth rod, there was just no earth, the woman at the house said the guy that put it in really know what he was doing and it took so time to for her to except it was luck no one had been hurt
Reply to new here working in France in the The Welcome Forum area at ElectriciansForums.net
hi guys / girls , any advice would be appreciated, So the situation is a domestic property has a 3 phase supply , from the service head we have 3...
Hi all. I have been asked to take over a job an electrician has started, and has moved abroad. The house is a big mansion, with a 3PH supply...
4K
Hi there, I built a house with ground source heating 5 years ago and it's a fairly large house so I have 3 phase supply 80 amps per phase. I had...
hello , Just a note to see if anyone been in the same sort of journey as me? I wanted to retrain as an electrician at 40 and on bad advice did a...
