Discuss New hoover - suggestions in the Electrical Tools and Products area at ElectriciansForums.net
O
Octopus
So my aged henry has given up the ghost....
do I just buy another or are there better products?
PS: Looking to spend this evening:hammer:
Screw fix Titan 1300w single motor - so many good reviews for a simple vac and last week was £34.99.
I've got a an Edward, larger volume Henry but don't really want to start using it for chasing as it might hate me back (we've been through a lot together)!
Drop it on the bench give a clean up. Unless some windings on the motor got burned up then new set of carbon brushes may bring it back to life...
Mine had on/off switch failing recently due to dust, got (temporary :) sorted by a wago connector and some tape, it now works right when plugged in.
one of my many jobs was working in a vac shop... some of these wall chaser vacs are good but for the money you still can't
beat a Henry for all round use. I used mine yesterday to get drilled concrete pieces from a 2ft fence post hole (no bag, just
filter).
Stihl SE62,is a cracking bit of kit. A mile better,than the 61 it replaced,and both physically and electrically tough.
I purchased one,on line for £99,and although a lot of lads rate the Henry...you are still able to crayon a face on the front,if desired :prrr:
My Edward NVR 370 has been with me since the flea infestation of '96. Two house renovations later, covered in paint and frequently used as a 'hop up', I am ashamed to say that I still have to give the moulded plug a whack to get it going! Perhaps, now that I'm training, I should lead by example and fit a new BS1363 plug. Would be a shame though as its a 'thing' we have - makes him smile anyway, well what doesn't?
Have you boys with Henry's use this attached to a chasing machine? If so, does it work okay (my Karcher Wet & Dry vacuum is good for cleaning up normal debris, but blocks immediately when attached to my chaser)?
connect mine to wall chaser with dome ally tube and gaffer tape. not perfect but it gets about 90% of the dust. as for the 10%, can't have the woman of the house sitting on her pretty arse all day, can we?
Reply to New hoover - suggestions in the Electrical Tools and Products area at ElectriciansForums.net
Hi All. Hoping for some advice please. I've severe arthritis in the hands (all three :flushed:) A large dollop of osteoarthritis but I'm also...
Am absolutely gutted, my Fluke 1587 insulation tester appears it's had an unknown fatal incident. I was doing some testing a few days ago and was...
I was working alongside the plumber yesterday. I had to drill some 32mm holes through joists. I always use my Makita 481 high torque drill will a...
  • Suggestion
So, I had a random idea last night about something new on the forum. It is more of a brainstorm at the moment but I wanted to ask you guys about...
Hi Guys, just looking for a bit of advise. I am booked up to go on 2391-52 soon, and was looking at using my own tester, Megger1552. It is all...
