O
Octopus
So my aged henry has given up the ghost....
do I just buy another or are there better products?
PS: Looking to spend this evening:hammer:
Screw fix Titan 1300w single motor - so many good reviews for a simple vac and last week was £34.99.
I've got a an Edward, larger volume Henry but don't really want to start using it for chasing as it might hate me back (we've been through a lot together)!
All my kit is Bosch which is why I switched to the Bosch Vacuum, it seriously is the best, I got all the additional attachments for it too.
If it's been a good servant over the years then get another, they are after all decent vacs.
Drop it on the bench give a clean up. Unless some windings on the motor got burned up then new set of carbon brushes may bring it back to life...
Mine had on/off switch failing recently due to dust, got (temporary :-) sorted by a wago connector and some tape, it now works right when plugged in.
one of my many jobs was working in a vac shop... some of these wall chaser vacs are good but for the money you still can't
beat a Henry for all round use. I used mine yesterday to get drilled concrete pieces from a 2ft fence post hole (no bag, just
filter).
Stihl SE62,is a cracking bit of kit. A mile better,than the 61 it replaced,and both physically and electrically tough.
I purchased one,on line for £99,and although a lot of lads rate the Henry...you are still able to crayon a face on the front,if desired :prrr:
Octopus,
Rpa07,
