Discuss New Kewtech tester in the pipeline in the UK Electrical Forum area at ElectriciansForums.net
Gavin John Hyde
Patron
Kewtech are at the later stages of designing the new MFT, like all the others will be made by Kyoritsu.
The new one will be largely based on this https://www.kew-ltd.co.jp/en/products/detail/01193/
Looks bold and different. from my point of view it will be essential as so many chargers now have type B RCDs built in that you need to test them. Should also be releasing one of the EV testing adaptors in early 2021 aswell. Whether I stick with Kewtech or go to a different brand will largely be down to price I think.
Not found a price for the Kyoritsu version yet.
The SPD test is interesting, wonder when we might find a AFDD tester on the market?
Kyoritsu 6516 Multi Function Tester Features​
DISPLAY ・Color LCD 3.5 inches dot matrix.
ATT ・Anti-Trip Technology (with 2 & 3 wire) for no trip LOOP L-PE testing on all RCDs.
・With 2 wire only, very useful in case of no Neutral (i.e. 3-phase motor lines).
LOOP ・High test current range of 2Ω with 0.001Ω resolution.
・Zs Limit compares the values required by Electrical Installations Standard with measured results.
RCD ・Type AC, A, F, B(General & Selective), EV and Variable RCDs.
・Single and Auto test, Ramp test and Contact voltage.
EARTH・Earth resistance test 2 and 3 wires with all accessories included.
INSULATION ・Resistance test 100, 250, 500 & 1000V with auto discharge voltage.
CONTINUITY・Continuity test at 200mA or 15mA with selectable buzzer for fast judgment.
PHASE ROTATION ・On 3-phase lines with clear indication of the sequence on the display.
VOLTS ・TRMS Voltage measurements 2-600V, Mains Frequency.
HELP ・Display shows how to connect the instrument according to the function selected.
SPD ・Surge Protection Device test, for SPD that uses varistor.
PAT ・Portable Appliance Tester function, for Insulation & Protective conductor resistance test
it would go with this?:
how often do you where that .lol.
I like the testers that show you a tick on the display pass or fail when testing ,me thinks megger is well
behind the times ,when other company's are done it . considering they the firsts to introduce testers in the beginning .
ticks are for sheep or plumbers that can't read numbers. I'll stick with my Megger that tells me the resistance is 0.25Ω or whatever, not a tick.
Reply to New Kewtech tester in the pipeline in the UK Electrical Forum area at ElectriciansForums.net
Electrical2Go - Megger MFT Deals! Upgrade your toolkit with our exclusive offer! Purchase any of the Megger advanced multifunction testers –...
Hi all, Grateful for your expertise regarding my confusion on the below. Context: French rural domestic property Single phase supply, TT...
Just thinking about selling MFT's and single test equipment. The idea being I buy stuff from Ebay and sell it on ebay, which I am doing at the...
Hi guys & gals, I gave in and bought the new Megger MFT-X1. Got my hands on it Friday night, had a little play with it, used it at work on Monday...
I bought the new Kewtech MFT - I wasn't expecting it until July. It arrived today so getting to grips with it. Not too different from the kt63...
