Discuss New kitchen wiring & appliances in the UK Electrical Forum area at ElectriciansForums.net
TheCodboy
Hi all, just looking for a little bit of advice from you very knowledgeable people. A new kitchen going in, bench top sockets, integrated dish washer & fridge freezer, gas hob with extractor and a double oven. The customer doesn't want any FCU at bench height or in the units so i was going to use grid switches for isolating the integrated appliances, hob & extractor. Where he wants the switches is more than 2 meters away from the gas hob. In fact he wants them on the other side of the kitchen wall (in the utility room). Any of you guys see a problem with this?? Also, anyone see a problem with running the extractor and the hob from the same grid switch?? (ie take a spur from the hob straight up to the extractor).
Whilst I often defer to the customer, i.e. doesn't want above worktop DP or FCU's, the appliance is gonna need somewhere for the end of the manufacturers lead to plug/connect into. Why don't they want 'in' floor unit sockets?
I was going to have a single box for the hob igniter and another single box the extractor. A 2.5mm t/e running from the grid switch to the hob single, then from the hob straight up to the extractor. Obviously fuse protection in the 3 pin plugs. Grid switch used to isolate the hob and extractor. It's just the distance I'm not to sure about.
With regards to nothing in the units.... Ive no idea. I did run that idea past him when he said no bench top stuff apart from sockets, but he seems quite fixed on the grid switch as a means of controlling them!
Well until electrical sockets etc become Wi-Fi, there's gonna be some 'box' in a floor unit somewhere. If they don't want above worktop DP, just put sockets under worktops. If they want a central grid switch, then C'est la vie.
Reply to New kitchen wiring & appliances in the UK Electrical Forum area at ElectriciansForums.net
Hi all. So I'm designing my new kitchen and trying to plan where things will go. I currently have a 6 switch panel for the appliances (hob...
Currently planning a new rewire for my kitchen and want to get things right first time when it comes to appliances consumptions and circuits...
Hello everyone, I'd like to seek your input on a matter. I'm in the process of designing the electrical connections for the following kitchen...
Hello, I’ve got an issue driving me crazy and can’t get anyone to figure it out as it’s not their issue. We had a new extension, single rear...
