Discuss New light fittings? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
As we are now working to the 17th edition, my answer is yes if the cables are not protected by earthed metal protection and is less than 50mm deep.
Others may have a different view.
Hmm, even when replacing like with like? I know what the 17th says but I think that its going to be a hard sell, especially if the customer has an old board with wire or no din mounted breakers. I don't understand how its possible to compete with the "cowboys" now. I was hoping I had missed something....
I was under the impression that if changing like for like you don't have to, and you don't have to certify it.....however I do as was told was good practice too,
My understanding of the 17th is...... if the building was designed to a previous edition then only the addition that you install needs to be to the 17th. So if you dont alter any cables then they dont need 30mA protection.
Even if you change a single light fitting in say a bedroom to 4 x spotlights BUT you use the existing switch drop then No 30mA protection is required
Lets hope Shakey agrees with me!
Mark
Reply to New light fittings? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi All I'm new here. I have just finished my NVQ and waiting to do my AM2. I have a question on selectivity as it has always slightly confused me...
Hi guys, Been asked to fit 2 lights and a switch, which in reality turned out to be rewiring a multiple PIR setup to a single switch, adding...
Hi guys, hope all is well. Getting hallway and stairs replastered/skimmed, do the light switches/light fittings need removing altogether for it...
As I've mainly done site work and moved into domestic recently, I'm a bit rusty on stuff like this, but if I'm adding a loft PIV unit to an...
Hi we are replacing light fittings in our home. Im confident with the fitting aspect, but have run into doubt in making the right choice of...
