This is an odd one.
I can’t see much wrong tbh. We could all go through each others quotes and invoices and pull some apart, but overall, it’s down to the customer to control the issue.
Also, unless we physically see all the works, it’s also hard to assess how much work was involved in even the most minor looking job.
I’m sure you could have got it cheaper, but being expensive is NOT the same as being ripped off.
Lastly, why is it that electricians work is always scrutinised but for example, people will pay a garage £500 for a service that involves no more than visual checks and inspections ???
the sparks always get in the neck, when customer never happy or customer paying to much ,so next time any body goes to see thier brief
that £100.00 pounds a hour and before they send a letter out .
Buzzlightyear the EICR and Pat testing was fine (actually £19.20 a circuit as the £288 included a bit of PAT testing) - it is only the labour cost that seemed high. I agree with the above comment, cheap doesn't mean good, but in this case I do feel that they took advantage of our being away. In the end, I guess it's a quibble over about £250 possibly overcharged and I will have to mark it down to experience. But it's been useful reading the comments. If we hadn't been in a rush and leaving the country with the house rented out I wouldn't have done it the way I did. A lesson for next time.
It’s ironic, because I truly believe...a proper qualified spark, has spent far more on training and equipment than say a mechanic or plumber etc.....
Yet because you can’t see electricity....we are somehow frauds
What do you think was excessive about the labour charge? You keep stating that you feel that it was excessive, but you haven't really expanded upon this.
Is it the £29/hour +VAT aspect that you find excessive, or simply the number of hours invoiced (or a combination of the two)?
The number of hours. £35 is the going rate in my area so I didn't have a problem with that. The £393 (which appears on the £845 invoice) issue did get broken down when I insisted, and it turns out that to replace a loft light fitting, fit 3 circuit breakers, fit 3 bathroom lights, plus 'install a new earth bond to incoming oil supply pipework' took 4 hours. I think a couple of people here have hinted that they think the labour total (not cost per hour) is on the high side, and I'd agree. Not a tragedy, but a lesson learned.
Cat...with all due respect...you haven’t shown us one thing that supports your claim that you’ve been overcharged on the labour side of things.
I see a pretty good EICR and a very open and precise invoice. Cowboys don’t tend to itemise everything cause it makes it harder to pull a fast one.
You also haven’t said what response the spark gave you after you queried the amount ??
They should have been your first place of enquiry and not on here. I’m guessing you thought you’d get some evidence from this site before confronting the sparks.
4 hours doesn't sound unreasonable for that, but as with others I haven't seen what was involved with the work.
I think the invoice is s**t, I can't make head nor tale of it. Thats where the problem lies.
It clearly defines labour/parts/hours....what more do you want ???
Once again...I’m not saying it’s the best invoice ever...but it’s more than satisfactory.
Also, if the customer wasn’t a more detail...then fine.
Thanks Risteard - as long as people here feel it's within reason I can take it on board. If we paid a premium, it was because we were in a rush. But I get the general feeling that that's all it is.
