Duxmaxer
Hi people,
new to the site and have a question about the different office lights available.
The fluorecent tubes fitted in part of the office at work are dieing and was told that the tubes that fit are no longer available. They are T12 4 foot tubes
I know T8 tubes have the same pin distance but the fittings will ONLY work with the larger diameter T12. The fittings are in a false ceiling and there are 4 tubes per fitting.
So my question to you is.
What would be better?
A. getting T8 fluorecent replacement fitting and tubes
or
B. LED fittings
I have heard that LEDs can be cheeper over time but when looking they where at least tweice as expencive as fluorecents. Is it possible to make up for the difference over there life span in the electric bill.
LED fittings should last a lot longer than fluorescent tubes but the energy use is about the same.
I would agree with ian that replacing the control gear would be cheaper than new fittings, bit surprised the T8's do not work.
LED replacement "fluorescent" tubes (which require the ballast bypassing) would also be less cost than new LED fittings and less work than replacing the ballast as well, you might make the saving there.
Thanks for the ideas. Might look at how much replacing the control gear will be.
The reason T8's willl not fit is that the tube is held in by terry clips and not where the pins connect, T8's will fall through the clips.
Duxmaxer,
Duxmaxer,
