Discuss Nissan dualis front right indicator in the Auto Electrician Forum area at ElectriciansForums.net
Looking for quote for Front right indicator fix.
Front left and back right and left work fine.
I replaced the Front right with a new globe and it didn't fix it.
When I look closer there are 2 wires that appear to be going across the back of the headlight to the indicator and one is cut.
Any ideas?
Price?
Hi,if the cut wire is the issue,any decent vehicle technician should be capable of repairing it.
As for cost........anything from a possible freebee single connector job....to a £150 soldered,heatshrinked loomed up repair.
Rear left indicator is another story....
Has it worked previously while you have had the car?
Reply to Nissan dualis front right indicator in the Auto Electrician Forum area at ElectriciansForums.net
Hi All, I've installed a Lorex doorbell recently, but it is not turning on. I did some tests using a multimeter and this is what I found...
Firstly, I hope it is ok to discuss the wiring of speakers here. TBH my ignorance in all things electrical knows no bounds, and I am guessing it...
The symptoms its been having to start with was the fuel gage only working sometimes and when i play music from my phone when a loud song came on...
Hello I have a central heating system, with a Y plan layout. The neon indicator on the thermostat seems to be sometimes dimly lit / flickering...
I bought this house a couple months ago. It was built in 1952 (same as me) but has been rewired with yellow 12 awg Romex dated 2007. Looks like a...
