Discuss no earth terminal. what would you do? in the UK Electrical Forum area at ElectriciansForums.net
telectrix
Mentor
as title. using existing back boxes ( lighting) as original VIR cable in capping and managed to re-use route to save chasing. boxes are tight and nailed in. removal would cause a lot of damage to decor. no earth terminal in box, so my solution was to drill the side of the box and fit screw. obviously a 2mm HSS bit is no good to drill into the brick, that's why it's in the side. would have been neater if I'd gotmy box of ring crimps on site, but hey ho. at least the box is earthed.
That looks terrible. Drill and tap with crimps and shake-proof washer.
it's compliant. domestic jobs - no wriggle room for the extra hours that would take. original was 1950's no cpc on circuits whatever. customer may want to change to metal switches in future, so cpc's are there.
Done exactly that in the old days Tel, but not used a countersunk type screw, but if that's all you have, hey ho jobs a good un.
By the time you have faffed about trying to get those cpcs around that screw I would have drilled and tapped the back box. I guarantee I could pull those cpcs off with little effort.
doubtfull each wraps round screw twice.
nice job ,are you out of your apprenticeship yet .:rolleyes: it saves you using a sledge hammer to it .
I would have done exactly the same, ideally a pan head screw would have been better.....but it’s earthed and that backbox will be far better quality than the wafer thin sh*te we have today!
Dejavu - come near this backbox and I’ll scream for help!
You’ve obviously threatened to pull something apart before!
Get some multi-drill bits to drill the box and masonry, might bugger the tap after a while but at least you have a decent connection.
sod it.i get a R1+R2 = 0.67 ohms. approx 30m of 1.0mm T/E. ticks the box afaik.
I have one of these in my van for jobs like that.:rolleyes:
New posts
Reply to no earth terminal. what would you do? in the UK Electrical Forum area at ElectriciansForums.net
So a quick catch up so you can get an idea… I was asked to do a job for another electrician, as he is too busy. I’m busy myself but said I’d...
I thought I would take a few minutes to give my recent experience in wiring a large garage for power and an alarm circuit. This relates to clipped...
Morning All I recently completed my first re wire and board change, (with help from the owner who is a gas fitter and plumper, who works with my...
Looking for some advice; I am intending to mount two led downlights on pillars/brick walls either side of the garage door opening. I will drill...
The situation is: Power is needed inside a greenhouse to power a specialized greenhouse heater, a timed motorized window opener and a light. The...
