Discuss No power in only one room and no RCD tripped. in the UK Electrical Forum area at ElectriciansForums.net
RDB85
Trainee
So last night I went to put my heater on in my room, it’s one of those oil filled ones that you plug in. So went to turn on my light and no power. So checked everywhere else in the house and all working. Checked the fuse board and nothing has tripped.
So checked the plug on the heater and it’s burnt a hole in it and on the socket plate. Now I’ve unplugged everything and I’m going to reset the fuse board and see if I can get power back.
Would anyone have any suggestions as to what to check, surely it should have tripped the RCD.
Need more info, the light is dead that could be the lamp so check that, the heater could have a short in the plug top and could have burnt through and damaged the socket. Is there another socket in the room that you can plug something else in to to check if there is power?
There is also a "friendly" member on here that lives in Liverpool so maybe he will pop up in this thread.
Photos also help.
If you have a burnt socket that would point to a loose connection, best to get it sorted before you use the socket or it's associated circuit, like SWD said there is a member based up your neck of the woods who may be able to help.
As above- probably a loose connection on either the terminal in the plug, or between the plug pins and socket outlet.
As a bare minimum the plug and socket would want replacing, and a test of the circuit done to ensure all is OK.
Have you got a photo of the socket?
As SWD says, our 'friendly' local spark may be willing to have a look.
replace the plug and see if that cures the problem. otherwise pm me and i'll fix it 4 U.
Not sure if I misunderstood, but I thought you said the room lights weren't working either?
They were not, but they are all on the same circuit, as there is one for upstairs sockets and one for upstairs lights. I reset the breaker on the RCD and they are now all working.
Ah, your original post said only one room was affected and the rest of the house was OK.
It was just one room, but I reset the RCD once finished then checked all the lights and sockets upstairs, to make sure there were no issues. All sorted with help and advice from the people on here.
Reply to No power in only one room and no RCD tripped. in the UK Electrical Forum area at ElectriciansForums.net
Hi, I seem to have an RCD that keeps cutting the power at random times without actually tripping, if I reset it, the power comes on and will stay...
Called out to fault on RCD tripping maybe twice in a month for sometime. Did all the tests & found RCD was faulty, Refitted a new Rcd Type A which...
Hi all, Been a while since I have been on here. I have been on an apprenticeship the last 3 years training in the BMS world. Taking that into...
An RCD keeps tripping. Please see attached photo of the board (2 photos attached). I’ll call the breakers: MCB (1) marked ‘Upstairs lighting’...
We have one room that seems to have lost most of its power last night. One of the outlets in the rooms has a power strip plugged in that powers...
