Discuss No power to post lights in the UK Electrical Forum area at ElectriciansForums.net
how have you checked that there is no power?
Just L - N?
So where are they fed from....a junction box or a switched fused spur inside.....
How do you turn them on
poor connection at switch? even at panel. 20 minutes of a qualified/competent sparks time would find this.
Can you clarify if these are controlled by a sensor (PIR) or not, please. If they are, then my money is on the PIR having packed up.
I don’t think sensor. The wiring is not hot. I have a gfci from a bathroom that is tripped and I cannot find where. There is one outlet that has no power. I changed out the outlet but the wires are not hot. Maybe the issue? Any advise it greatly appreciated!!!
Reply to No power to post lights in the UK Electrical Forum area at ElectriciansForums.net
Hi, I'm adding American muscle's halo fog lights to my 2006 v6 mustang and am looking for a good place to connect the positive side to power the...
So a family member wants to put an outdoor light or two on the end of a driveway, purely passive and solar powered. These used to be naff and not...
GFCI green light is lit when not under power draw. The bidet seat functioning causes light to pulse yellow (and creates a pulsing and knocking...
Hello, I would liked to install a Byron wired doorbell with built in chime and 8v transformer. I'm struggling to get power source. I have a...
I am trying to understand how a relay system works and have designed a circuit and a ladder diagram all as attached for an 8 PIN relay, a current...
