G
Grant M
With regards to main bonding, what is the solution if there is no sign of a water mains? The plummer says the stop cock is outside the property in the street and there is no off valve coming into the house.
Should be bonded within 600mm of the origin so as near as possible to where it enters the building
find a plumber that knows what he is on about,I've seen literally thousands of properties and never one without an internal stop cock,outside stop cocks on older houses that knock off 2 or 3 properties but never nothing to turn off inside,what happens if the pit gets blocked and you can't get at the tap? get him back and this time ask him to bring his guide dog.
"Stop",now reverse that quote
Ever been to Wales phill,the opposite can also be true with us![]()
It's not uncommon to have to stretch into the pavement at arms length in many of our properties
I know of one on the sea front at Rhyl just like that.
She must be a big girl then Geordie
I'm not understanding this convo.......:thinking: wotcha on about Humpty?
