Discuss Non maintained EM switching in the Lighting Forum area at ElectriciansForums.net
S
sparky in training
Hi All
I was replacing some faulty fluorescent lights yesterday when I cam across one with an emergency light attached to it. It was non maintained as once I had isolated power it switched on. When I cam across this light I could see it was an afterthought as the original light was wired in old colors, red black and green for earth whereas the EM light had new colors.
Turned out to be a tricky job because the new light wouldn't fit where the old light was so I had to adjust things and trim conduit back etc. Ended up just using push connectors to rewire the fitting.
Anyway, my question was what causes this EM light to switch on when power is disconnected, it has a permanent live going to it to charge the battery, is there some sort of relay internally that allows the battery to take over and power the light? For that matter, do maintained EM lights have a relay that switches over to battery supply?
Hi All
Emergency Lighting Explained - Mount Lighting - http://www.mountlighting.co.uk/emergency-lighting-types-explained/
Best description I could find
The emg light has done what it's supposed to do ,you disconnected the power supply so the light went into emergency using the power from the battery's which the supply was charging
I know that, my question was what internally causes it to switch allowing battery power to flow
Probably all solid state electronics but basically a relay/sensor of some sort will be aware of a loss of mains electricity and switch over to battery power, on reinstatement of power the reverse happens and all is honky dory
You'll find that answer on the 'electronicsforum.co.uk' - to me the answer will be - "I don't care as long as it does"!
We have got to a point in today's society where everything is thrown out, swapped out and renewed. The amount of useful stuff that is disposed of hurts me to look and quite often find myself keeping this bit or that bit 'just in case'.
Respect for your quest for nano learning but sometimes you have to jump fully in or ignore why and carry on!
Obviously my own views - we all have a passion for why certain things work but 'everything ' takes it too far.
I look at PCBs and just shake my head at the amazing ability man has to create something so small that is so powerful then I'll look through glass and i'm amazed at how laminated glass can still be so see through! You get me!
How I get so much work done, now that's a good question!
Reply to Non maintained EM switching in the Lighting Forum area at ElectriciansForums.net
I am trying to understand how a relay system works and have designed a circuit and a ladder diagram all as attached for an 8 PIN relay, a current...
Hi all, I'm in the UK and have recently had a ducted extractor fan Mixflo 200W with timer fitted. The fan comes on with the pull cord and runs for...
DIY query Have narrowed down the source of an occasional trip to one light circuit which is a varilight v-pro master dimmer slave set up. This...
Im trying to make a Star Wars Prop for a course project where the dealine is comming up very fast in days and I need to do the report so really...
Hi everyone :) my first post here. Quick background I'm a newly qualified installer of somewhat advanced years whose just starting out in the...
