Hi,
I just bought a Nova 2218 hair cutting tool from Amazon.
It has a charger cable with a "~110V" 2 pin plug for the mains.
The device seemed very light to me, so i doubted there was a mains input stage in the device.
Therefore i took it apart and yes , there is no diode bridge etc.....its just a small battery and a few resistors and diodes and caps.
Do you know what type of battery its likely to be? Its a cylinder of size approx 2.5cm length and 1cm diameter
I think it will be a 3.7V lithium cell......so i guess i am ok charging it with a 100mA constant current charger with a max voltage cutout set to 4.2V?
Does the plug state it is 110v because it looks like a plug for a shaver socket.
If it's marked 110v A.c then it must have "a mains input stage" somewhere, most likely within the plug.
Just plug it in to a 110v shaver socket, or better still send it back and buy one designed for use in the U.K, assuming you're in the U.K
southampton
Electrical Enthusiast (Unqualified Hobbyist etc)
Nova NS2218 Hair cutting tool
Electrical Tools and Products
treezleef,
snowhead,
