Discuss old style wireable CU in the UK Electrical Forum area at ElectriciansForums.net
As mention earlier the installation will probably be OK until you start taking it apart to have a look, I can see it now just taking a socket off to have a look and the rubber falling off leaving bare copper cable!!! then the option will be to turn off the supply to make it safe
Or sleeve it, only joking it's normally the lighting circuits with these old cables that take a hammering.
oh would it now?
i think not....
see as it would have been as a result of your investigations that the insulation `fell apart`...then you would have a duty of care to make a repair....even if only temporary....
as you also have a duty of care to leave the occupants with adequate power for lighting and outlets....
Reply to old style wireable CU in the UK Electrical Forum area at ElectriciansForums.net
I have been asked to change cu from old fuse board which has 6 fuses. Only 4 fuses are used. The first fuse feeds cooker circuit. This is not used...
Hi everyone, On a job at the moment and trying to Work out cable size needed for property supply. Lots going on and struggle to work out...
Hi guys, I have supplied my Shed with a 6mm SWA cable into a nice consumer unit. In there I have a 6Amp MCB for the lights and a 16 A supplying a...
Hello. I live in a new build house with a separate garage. The garage is connected to RCD in the house to a 16A circuit breaker. The cable from...
