Discuss old style wireable CU in the UK Electrical Forum area at ElectriciansForums.net
OP: Please can we have some pics of the boards and cables, then perhaps we can guide you as to the age, likely faults, things not to disturb etc. while working out a plan of action. FWIW the oldest cable I have in service in an installation is over 100 years old and fine, while some from the 1960s is no good. Glenn is on the money with it depending on the installation's history and a bit of it is just luck as to how long stuff lasts.
yep...its all about the environment its in....the times (and the magnetude) of fault/s it has been subjected to....
the levels of loading under normal conditions
installation method...
the list goes on....
oh would it now?
i think not....
see as it would have been as a result of your investigations that the insulation `fell apart`...then you would have a duty of care to make a repair....even if only temporary....
as you also have a duty of care to leave the occupants with adequate power for lighting and outlets....
That was what I was getting out you could end up opening a can of worms just by taking off 1 socket :oops: so message to OP is be care full when doing your inspections
hi all sorry i gave up checking forum replies as i was getting loads of messages about playing chess etc lol, yes i will sort out some pics of the installation when i go back next
all the best and thanks for all the advice
New posts
Reply to old style wireable CU in the UK Electrical Forum area at ElectriciansForums.net
I have been asked to change cu from old fuse board which has 6 fuses. Only 4 fuses are used. The first fuse feeds cooker circuit. This is not used...
Hi everyone, On a job at the moment and trying to Work out cable size needed for property supply. Lots going on and struggle to work out...
Hi guys, I have supplied my Shed with a 6mm SWA cable into a nice consumer unit. In there I have a 6Amp MCB for the lights and a 16 A supplying a...
Hello. I live in a new build house with a separate garage. The garage is connected to RCD in the house to a 16A circuit breaker. The cable from...
