Discuss Open knockout holes covered up ? in the UK Electrical Forum area at ElectriciansForums.net
Hi all
when doing EICRs and you open up your 10% of accessories what would you code a knockout hole that has a 20mm open grommet on a metal box with no cable coming through. Only insulating tape and duct tape over the top of the 20mm grommet. Would you even code it as if you have a 20mm open grommet with 1 x 1.0 mm t&e still a lot of room around hole. Just looking for other views to weather or not this even requires coding at all. Thanks in advance ?
The duct tape and insulation tape are not the answer, the fact that it behind a plasterboard wall is the pertinent point regarding the IP rating. look at installation with out the tapes on it, they are superfluous, is it possible to stick something in the hole ?
Hi we are not carrying out repairs just doing EICR then have to code what we find. Now this box is behind the plasterboard can’t be reached, only when open up switches noticed they have covered holes with open grommet then duct tape on one then insulating tape on another. My thinking is, no code as the hole is covered. Now if you think about a 20mm knockout with 1.0mm t&e through that hole there is still plenty of room for foreign objects to go down but no one codes them ?
Even if its a surface box with a hole covered by gaffer tape then I don't think there's much to say about it.
Gaffer tape is harder to remove than a blind grommet and they are acceptable.
What do you mean normal stud walls? What is the difference?
A stud wall designed to be a fire barrier which requires things like back boxes to be fire stopped is different to a normal stud wall.
The few I have seen have always had a double layer of 15mm plasterboard.
A normal stud wall is usually a single layer of standard plasterboard.
The internal dividing walls of a property or fire compartment don't require fire stopping for the back boxes.
Only the walls which form the dividing wall between fire compartments, such as the walls between flats, would need fire stopping.
Reading various docs I find it can be not so cut and dried. There is the idea of a fireproof wall needing fire pads in the socket that I can see. There is also regs which require any connection to be fireproof. I think 421 and 625 off the top of my head. Although thin metal galv can be seen as fireproof, when a hole is left in it then the fireproof nature of the containment is compromised. It is clear, among other items, that penetration of any stud wall (or ceiling/floor) with electrical connections/accessories does increase risk of fire where there is not fireproof containment. Just to distinguish the two ideas, one is the fireproof nature of the walls the other the fireproof nature of electrical accessories/connections in stud walls. I am undecided as to what is the final fact on the matter it is open to interpretation as usual.
Would an open grommet with one or two cables through it be any more fireproof than an open grommet with no cable?
Reply to Open knockout holes covered up ? in the UK Electrical Forum area at ElectriciansForums.net
Most of the work I do is additions and alterations in domestic properties, and other than swapping accessories and lights in new-builds for...
So I had a ceiling repair done in my bathroom due to water damage. The neighbors toilet above me was leaking for who knows how long. Mold...
So I just started out recently and I’m struggling with what to price myself at. It’s worth noting I live in the east London area and I’m looking...
Hi all, Disclaimer: I'm not an electrician and have very basic knowledge of electrical installation. We've been putting in a new kitchen into an...
Recently visited a new build to do a very minor job and spotted a few dodgy looking items so Client asked me to do an EICR. Following items I...
