- Reaction score
- 0
Hi,
Looking for a bit of advice on the correct type of switch. I have a sprung vending machine coin return pull, the end of the rod (inside the machine) needs to operate a 12v on/off momentary type switch. So when the lever is in its normal position, then end is pushing the switch in & it's off, when it's pulled, the rod travels enough to release the switch & turn it on, when the lever is let go because its sprung the rod presses back on the switch, turning it off.
The ideal thing would a momentary switch (like a bell push) but the opposite way round so its off when its pressed in, on when its released.
Could I wire a micro switch to do something similar? I've seen latched switches, but from what I can work out, they don't return like a momentary switch?
Thanks in advance,
Thanks in advance,
