Discuss Outbuilding on non RCD side of C/U? in the UK Electrical Forum area at ElectriciansForums.net
N
Nicebloke
If running power to an outbuilding (usually a garage at the bottom of someones garden), I normally run it from the non RCD side of the C/U in the house and then put a 2 way RCD protected C/U in the garage. I was however, told that I can no longer do this as it must be connected to an RCD in the house C/U. I was also told that any outbuilding more than 20 metres away from a house must have it's own TT system?
where did you hear this?
Surely yours is the best method, as long as the cable has physical protection (i.e. not triggering the cables in walls reg). Having RCD in series is difficult to discriminate and the longer the run the more impact it has. A lamp blows in building2 at night and trips a board in building1 a 100m away creating an unnecessary hazard, imho.
Edit : and the reverse, a problem in building1 takes out RCD covering building2
I am with Stroma. With regards an outbuilding requiring its own TT system if it's more than 20 metres from the house, I can't see where he got this from?
out of a chinese christmas cracker, i'd assume. what a load of bollox.
While there are arguments to support that thinking, it is only one way of doing it, there is guidance to download called Exporting PME. If I put an RCD at the house I personally would only use that for the cable protection supplying the garage and do a TT at the garage. I understand the DNO do not like exporting PME too far from the origin as it may defeat their PME. But the above is not set in stone, there are other approaches.
Exporting Pme - http://www.electriciansforums.co.uk/resources/exporting-pme.101/
This is where it all goes wrong when you have different bodies giving different opinions, and within those bodies you have people who seem to have their own misguided opinions. One body, one set of rules is what it should have been.
Reply to Outbuilding on non RCD side of C/U? in the UK Electrical Forum area at ElectriciansForums.net
So as the title says can I use a mcb as the main switch. Basically to keep it short I’ve took a 25mm sub main to power an outbuilding. Mains...
Afternoon all, Got a bit of a strange one (by my usual standards anyway). Job is a large barn conversion, done years ago, there's loads of work to...
As the title says, I am looking for a recommendation for an enclosure and gland arrangement to electrically isolate or divorce the earth/armouring...
5K
Hi Guys, Long time member and not a regular user here. I do pop in here when the odd unknown pop's up and unable to locate an electrical dilemma...
Hi all, Grateful for your expertise regarding my confusion on the below. Context: French rural domestic property Single phase supply, TT...
