Hello,
I am looking for an outdoor junction box for a night flood light. Most boxes I see have openings from sides of the box only. I would like the junction box to be installed on top of the wire coming out from the wall and have one wire going out from the top to light. Any ideas which box would be suitable?
Thank you.
I use a one entry conduit box, glue a short length (just long enough to fit in two fittings) of conduit into the hole and then glue a female converter onto that and put a gland in the end. If you've got good quality PVC cement knocking around, this may be cheaper and seems to work just as well. Drill a hole in the back and then ring it in sealant and screw it to the wall.
Thank you very much.
BG double weatherproof socket.. they have entry holes top bottom and side. Can't see a problem if you use rated compression glands but side entry then turning upwards would be preferable I suppose.
but OP wants rear entry so the cable coming through the wall is not shown externally. a short length of 20mm pvc consuit throuh wall and protruding 1/4" into the box or with an adaptor, coupled with sealant between box and wall is my preference
London
Outdoor Junction Box with wire from back
DJDJDJDJ,
telectrix,
