Discuss Outdoor Junction Box with wire from back in the UK Electrical Forum area at ElectriciansForums.net
Hello,
I am looking for an outdoor junction box for a night flood light. Most boxes I see have openings from sides of the box only. I would like the junction box to be installed on top of the wire coming out from the wall and have one wire going out from the top to light. Any ideas which box would be suitable?
Thank you.
I use a one entry conduit box, glue a short length (just long enough to fit in two fittings) of conduit into the hole and then glue a female converter onto that and put a gland in the end. If you've got good quality PVC cement knocking around, this may be cheaper and seems to work just as well. Drill a hole in the back and then ring it in sealant and screw it to the wall.
Thank you very much.
top entry would be OK if box was mounted under soffit. otherwise bottom entrty with drip loop in cable is advised.
BG double weatherproof socket.. they have entry holes top bottom and side. Can't see a problem if you use rated compression glands but side entry then turning upwards would be preferable I suppose.
but OP wants rear entry so the cable coming through the wall is not shown externally. a short length of 20mm pvc consuit throuh wall and protruding 1/4" into the box or with an adaptor, coupled with sealant between box and wall is my preference
Agreed! A bit of silicone squirted into the wall holeafter conduit and cable fitted will work a treat. Use the right size drill bit for the conduit and it will be nice and tight. I am a big fan of the Wiska box.. you can screw the gland straight into them, you don't need a backnut. If no junction inside the box it will be 100% reliable. If need to join wires inside, use wago terminals.
Reply to Outdoor Junction Box with wire from back in the UK Electrical Forum area at ElectriciansForums.net
Hi, i live in a new build house where they builders have left a junction box on the outside of my house. In the junction box there is a 6mm twin...
Hi, Hopefully I haven't made an error but I was speaking with another electrician and he said standard junction boxes with screw terminals can no...
Hi Everyone, Sorry in advance if this is a silly question. There is a junction box in my mother's kitchen, on the wall above her kitchen...
Hi, I'm looking to install a new bathroom extractor fan in my bathroom as I have a windowless bathroom and the current one I have installed in...
Hello, First of all, thank you in advance for any helpful insights posted in response to my question. I have just moved into a new home. With...
