How do you know they are dimmable, most won't be.
You will probably need to buy new units that do colour changing AND dimming...
My limited experience with those are that the warm white is more of a yellow. Excuse the link to the cool white fittings.
I guess I'll swap them out with dimmable warm white floods. If possible..
They are not dimmable.
LED's that are dimmable usually say they see.
You also need to use a leading edge dimmer switch, as standard trailing edge dimmers need a minimum of 60w to work. And given most LED's are a lot less than that, they simply won't function.
LeeH
Lincs
Outdoor LED flood dimmer?
Lighting Forum
LeeH,
Paul228,
