Discuss Outdoor Socket Supply in the UK Electrical Forum area at ElectriciansForums.net
jt123
Hi all
I am in the process of having some garden renovations done and would like to have an additional outdoor socket installed. I have a Cabin in the garden; a 10mm cable runs from the DB on a 32a RCBO up to an exterior Wiska box, where it connects to a SWA and runs underground to the cabin.
Is it acceptable to have a socket using 2.5mm T&E (in conduit) from the Wiska box? Presumably with a FCU to fuse it down to 13a in line? It would be a short run of 2.5mm (about 30cm).
I am not an electrician and I fully intend to get a qualified to do the work, I do however have an interest in these things and tinker about with Auto electrics hence why I like to have an understanding of what needs to happen :)
Thanks for any advice.
Depends how the cable is jointed. If it’s in sleeved crimps then I would not Try to attach another cable to it.
if it’s in connector blocks then you could dab in a 3rd cable but again it could already be very tight squeeze so not ideal.
might be easier to come of a local socket in the house...
as the wiska box is on a 32A RCBO, you could spur off to a socket in 6.0mm ( Iz = 47A ) without fusing down. if you are goingto employ a sparks, post your location. one of is is probably close.
I used to have some big 50a Bakelite connector block which would just about accept 2 x 10mm conductors , getting an additional 6mm in would have been difficult
henley blocks in the wiska box ?
If it's a single/double socket outlet, yes you can use 2.5mm^2 to feed a spur, no need for a FCU as the plug's fuses will provide overload protection for the cable.
However:
Depends on how the existing swa/internal cable is connected - may not be possible to physically add.
This can only support one socket outlet - if you need to add two separate outlets, either need to use 6mm^2 or use an FCU with 2.5mm^2
This is all subject to an electrical test to ensure the available fault current will trip the RCBO in less than 0.4 sec, this is done by measuring/or calculating the Zs value. Your electrician will be able to work this out upfront
although it would be safe, either way, the circuit is a distribution circuit to the cabin and it seems wrong to add aceessories to a distribution circuit.
strange... both pete and i both have identical points, 18666. if points make prizes, i'll take mine in used 20's and 10's, no consecutive serial numbers.
The last 3 digits are ominous...
Don't even know how many I've got.... not that I'm bothered about it. I might just have 666
youhave 18,688. close but no prize. i'm on 18,688 also. must be a brexit/covid/5g conspiracy. big brother dan is watching. if so, pleeese dan, bring back smileys and the facility to score out words.
Never really noticed the trophy points thing before, but I've also got 18688 apparently. I think something is wrong!
Thanks all for your replies. The T&E & SWA connect in a big white connector block in the Wiska box (60a I guess?). I was wrong, the cable running from house is actually 6mm not 10mm- which may make adding an extra cable easier. I will post a picture later of the connections. Again, thanks for the info. I have an electrician coming next week to do some other work for me so will get him to take a look. Your replies just give me a good idea as to what may be needed, so thanks again.
Click on the 3 dots to left side of reply box and strike through appears with a few other options.
got that. now where's the smileys. i have to upload my own.
Could then use a 3 way Wago 221 connector or a Wago item no. 773-173.
all wagos are 1 way. they may be 2,3,4, ... 8 ports, but still 1 way
Ok, I'll agree with you there mate... But it's also refered to 'ways' in some catalogues, like RS.
Reply to Outdoor Socket Supply in the UK Electrical Forum area at ElectriciansForums.net
I found a 13A FCU, connected to the kitchen ring supplying an outdoor junction box, providing two SWA 2.5mm radials. Unconventional? yes. One...
Evening everyone . Currently looking at pricing a job up . It’s a hot tub supply . Outside socket with a few spare ways in an outdoor cu . 10mm...
i have just started my course as a trainee electrician...some advice on the following will be appreciated: I have a spare 16 and 32A MCB (RCD...
Hi, i live in a new build house where they builders have left a junction box on the outside of my house. In the junction box there is a 6mm twin...
Hi all, I have a log cabin in my garden. An electrician ran an armoured cable from my consumer unit to the log cabin and this terminates on the...
