i wouldnt consider anything but fp200 for a weatherproof lighting cable that was clipped direct without any further containment.
The Electricians guide to the building regulations mentions the recommendation of not using grey or white cable outside only black recommended, but as has been said grey T&E can last for ages (sometimes).
Oh yes and B&Q sell 1mm² black rubber flex, but any wholesaler should have black PVC flex. (should also have rubber but often don't)
Hi-tuff or NYY-J is my preferred option in this sort of situation if a longer run is required, rather than just a short loop of flex into a fitting. Readily available in various sizes and number of cores from 1.5mm² upwards and easy to terminate. Sheath is tough UV-resistant PVC.
Only snag is that 3x1.5mm² can be a bit fat for some lighting glands.
Why not use plastic conduit with bush coupler and copex into light fittings.
Why not pop into bnq i know there is a big one (can't remember where in lincoln haven't lived there for over 10 years)
LIES
There is NOT and i repeat NOT a B&Q in Lincoln.
Hi Ian.
I have looked and looked for 1mm H05RN-F which would fit the minimum criteria for CSA and also the type of cable recommended in most of the maunufacturers leaflets but I dont think it exists!
So you either go for 1mm H05RR-F which you can buy from B&Q or if you want to be really good and correct then 1mm H07RN-F from the following place (a good place shown to me by Murdoch):
https://www.electric-cable.com/rubber-cable-h07rnf.php
I was very interested in this debate so I contacted Prysmian cables tech dept for their take on this,below is their reply.
[FONT=&quot]Good Morning Phil,[/FONT]
[FONT=&quot]You are correct to say that this cable is not designed for outside use. As you point out the obvious one is that it is unarmoured and therefore could be mechanically damaged. In order to avoid this then it should be protected (conduit trunking or capping) or positioned ‘out of reach’. The problem with ‘out of reach’ is that it could then be subject to the weather, and as you mention sun light (UV). The PVC sheaths of these cables are not UV stabilised or designed for ‘heavy weather’. Armoured cables do have UV stabilised sheaths and are designed to get wet. Even then if you want to ‘extend’ their life you would install out of direct sunlight.[/FONT]
[FONT=&quot]I have also seen shortish lengths of twin flat running under a sheltered soffit (out of reach) to a light for example and I would say that seems reasonable. But long lengths of it I would say is not suitable. [/FONT]
[FONT=&quot]Phil, let me say also that we are not an approval organisation and so I suggest you should also ask your trade association (NICEIC). I know you can do this on the Voltimum site if you want.[/FONT]
Beevor road off tritton road
LN6 LDJ
I think you need yours eye's testing pal its hard to miss
You are still lieing....there is NOT a B and Q in LINCOLN ............i think you need your eye's testing, as you are unable to read (or spell) :)
Haha, im too funny.
But seriouslly can't believe you've fallen for that, i was got with that joke many moons ago.
I use it , I like it, easier to handle than swa not many garden situations it can't handle.
Haha, im too funny.
There's no apostrophe in 'eyes' either. Daz
