Discuss Outside lights in the Canada area at ElectriciansForums.net
U
Unregistered
Can outside PIR activated lights be wired directly to the consumer unit. So that there is then no need for switches etc?
My CU is a WYLEX 11 way with MCB's also fitted with an RCD
Yes so long as the correctly rated ocpd & cable are used.
I always put a switch in the circuit for pir lights, if only for isolation when changing lamps if the mcb is supplying more than one fitting.
Must confess I have just dabbed my outside PIR light in with the downstairs lighting. If I want to isolae it I can flick the mcb controlling it.
feed the sensor through a switch , that way you can switch on the lamp by make and break , lamp stays on for lenght of time you set , the fittings are designed to be used in this way .
Reply to Outside lights in the Canada area at ElectriciansForums.net
Hi, Heavy industrial spark here, never do house bashing hence the question. I currently have a light switch at the front door not doing anything...
Hi there, I have an outside light that is turned on with a switch from inside and would like to change it to a PIR version incorporating an...
I own two flats with a small common lobby. Although operable from both flats, the common lobby light appears to be wired to flat A's circuit...
I have a Security Light on my patio and until recently it worked fine. It stopped working and I couldn't decide if it was the LED Floodlight or...
Hi All, Would be grateful for some advice. Would like to add an additional light (Undercabinet 8W LED Batten light) to a two-way light switch...
