Discuss Outside/Porch Light Cable Routing Help in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
B
Buzz Lightbulb
Briefly, need to install an outside light sited at the front door, not PIR activated.
I can take the supply from the upstairs lighting circuit down the wall into the hallway and take it through the wall outside to the fitting. I need a switch near the door too.
Challenge is to abide by the 17th Edition regs, so it's the routing of the cables that I need some help with please guys. I could bring the supply down the wall, within the 150 mm from the corner, but it's where I go from there where I could do with some guidance. Can I channel into the plaster, horizontally across the wall (from the corner of the wall) to the hole (near the front door) for taking the cable outside to the lamp? And where can the switch go in order to abide by the regs? Ideally it's preferred to be near the existing switch on the wall near the door.
Any thoughts chaps?
Cheers for any help - asap please ;-)
Chris
Many thanks guys. Reading through the OSG for the 23rd time, I realised there is a vital "or" after several of the options which gives us more flexibility.
Thanks again for the time you put into your replies. Much appreciated.
Chris
Reply to Outside/Porch Light Cable Routing Help in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi, I'm about to reroute cables and sockets/switches from the ceiling down to the socket height after insulating a wall. I understand this will...
Hi, Heavy industrial spark here, never do house bashing hence the question. I currently have a light switch at the front door not doing anything...
Hi all, I am planning to install wall lights such as these ones (LAP Bronx Outdoor Up & Down Wall Light Black - Screwfix -...
Hi. Has anyone ever taking a feed from an outside light to use as a spur to fit an outside plug to plug in a plug in ring camera. The only feed...
Hi I've got an new outbuilding that needs power run out to it, the building is very close to the house and the original plan was to run an...
