Discuss Partial testing and R1+R2......... in the UK Electrical Forum area at ElectriciansForums.net
This is simply not true, the IR can be below the allowed value without the rcd tripping. It is just lazy not to do it.
On an EICR you only have do L&N to CPC so why not do it
These houses are very much lived in and cluttered to absolute buggery i have 2 hours in which to do the eicr im not going round unplugging absolutely everything!! Taking out all the lamps and disconnecting all fire alarms just to get an accurate reading.
Its not lazy im trying to do the best with what little time i have.
If i wanna say to my company hey im not happy with doing it this way even though you have been told by the niceic you can do this...im sure there response will be well good luck with your next job.
A luxury i cannot afford to do at the moment. So jump down off your high horse i will not be called lazy when im rushing like mad to get these things done in the time im alloted.
You ever done say a boiler circuit ln to e....i have without disconnecting it...got a false reading disconnected it got over 2Mohms same with a lighting circuit before now. Usb sockets have given me funny readings before now. I used to do the IR until i was told to speed it along and if its rcd protected dont bother.
Sorry but calling me lazy and being like that was quite rude.
Long as you feel like you have done a full and proper job testing an install for the safety of the tenant and are happy signing the cert carry on.
FYI I don’t seem to be able to test more than 2 properties in one day, maybe I just crap
I do not like having to do partial tests im much happier to do 1 full on thorough test in a day. But when i do them i do make sure they are as thorough as i can make them and i make sure rhe install is safe. I have on occasion called the office to cancel my next appt so i can repair any faults/damage non compliance etc
I write all limitations downand also if i feel the property is in need of a re wire or anything such as a CU upgrade i will put at the bottom of sheet 1 my advisorys. In that sense my company has sent me to give my opinion, i have tested the property and i am issuing them a certificate with what i feel needs to be follow on work...whether they then act on it...
Im off...i have a night of sexless passion to get on with happy thursday
Reply to Partial testing and R1+R2......... in the UK Electrical Forum area at ElectriciansForums.net
Have only recently gotten in to testing. Doing an R1+R2 on a lighting circuit but instead of producing a result my tester clicks over and over...
Hi All Happy new year to all! First post but long timer lurker, so thanks for all the previous help! Just wanted to clarify something I have...
Hi All New to this forum, have read the posts on here from google but only recently signed up. I'm having some issues and some input would be...
Hi so i am doing a test on sockets on a ring Final circuit for family member. Got my end to ends r1 0.62, rn 0.64, r2 0.97, identified opposite...
