Discuss PAT earth bond lead in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
MTS
Hi, can anyone advise please. I am making up a earth bond lead for a meteral PAT tester just purchased as did not come with one. Its the 3 pin XLR connector common on a lot of testers. My question is how is it wired? Can i use 3 core flex and solder one wire to each pin in the connector then connect all 3 at the other end to the crocodile earth clip. Or as its mutipole does each pin have a seperate function.? Thanks
  • hilton-leeds.pdf
Brilliant thank you had sumised that as did a continuity test on the connections on the PAT tester port, but nice to get it confirmed.
Reply to PAT earth bond lead in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
Hi all, We have a limited in house PAT testing requirement and were advised that the TIS700 fitted our needs. The unit works fine for 110V and...
Performing the PAT inspection on some science equipment and I have found some items that were passed by the previous company that performed it...
Hi Hope anyone can help Can someone give me advice on how to connect up a 3 phase to 13amp adaptor lead for carrying out PAT testing on 3...
Hello, I am currently learning and have come across PAT testing an old chandelier. On modern lamps I would use the plug and probe on the...
Hi there, I was wondering if anyone could advise me on the WT Henley Series 8 house service cutout. I have one of these installed at my house and...
