G
goodwilld
Hi All
Can anyone confirm that by law i have to Calibrate my Pat Tester annually.
No but how would you feel and what would happen if you passed an item saying it was OK then somone got killed and it came down to the fact your tester was well out off calibration.
In regards to the Law, you have to prove (if anything goes wrong) that you have made a “conscious effort to maintain electrical safety within the workplace” So... It mainly depends on the size of your company, the type of equipment you’ll be testing and the frequency.
It’s always best to air on the side of caution. I found out a few weeks ago in court cases that breach H&S it’s up to the defendant to “Prove beyond all reasonable doubt that they did everything within their powers to prevent a foreseeable risk”
I would say that:
If your providing a professional service you should get your tester calibrated annually.
If you work with industrial / construction equipment you should get your tester calibrated annually.
If you operate & test a small office or other low risk environment it’s recommended BUT I know of many 1000’s of companies that do not calibrate their testers.
You could claim that by doing the Combined Visual & Electrical Safety testing you meet these recommendations, but that would be up to you to prove in court if anything were to go wrong.
These are only my personal views and I am in no way qualified to give legal advice.
Hope this helps....
No Worries! I thought it was only fair to share... it might help someone else in the same predicament.
"On Site Calibration Services" are pretty good -reasonably priced and wil come out to you.
[FONT=Tahoma,Verdana,Arial,Helvetica Sans]3 Dennis Brown Court
Saxilby,
Lincoln, LN1 2QZ
[/FONT]
[FONT=Tahoma,Verdana,Arial,Helvetica Sans]Tel / Fax : (01522) 703002
Mob : 07776 200146
[/FONT] [FONT=Tahoma,Verdana,Arial,Helvetica Sans]Email : [email protected] [/FONT]
Richardhammond, (topgear fame!!!!)
Bet you get that all the time!!!!
I use a company called ATC in the midlands, will travel if the numbers are right. £20 per unit.
Speak to a guy called Chris, mention my name Dave Goodwill id you use them.
Hi
Only doing occasional pat testing and am having tester calibrated bi-annually (supernova plus) - anyone know how to reset "nag" code?
Thanks.
Pat Tester Calibration????
Electrical Testing & PAT Testing Forum
goodwilld,
JEFFB,
