Discuss Pattress for old MK socket in the For Sale and Wanted Forum area at ElectriciansForums.net
Older -style but modern accessories google search brought up the art deco site mentioned earlier in this thread...
and also this:
I probably won't be replacing all my switches with these!
The double sockets are a bit cheaper though...
To continue the theme, I am beginning to construct a "vintage" board using older accessories.
My house actually has a couple of those old MK sockets with the 4 fixing screws, but I have a couple of other MK sockets, pictured here with an old light switch.
The diagonally opposed fixing holes on the white socket are a bit unusual, to me anyway, and the neat format, as also the neat format of the brown, round pin socket, please my eye.
Question:
The fixing screws are not the current 3.5mm. but smaller...I'm guessing 2.5 or 3mm. To save me searching, I'm sure somebody can confirm the size and a supplier.
The screws for the white socket were also captive, they never fell out although yours are missing. Tough as old boots they rarely need replacing unless they have suffered severe mechanical damage.
thank you @nicebutdim and @westward10 for you comments.
I did find, amongst my box of miscellaneous screws and bits a couple of brass-finish screws that do actually fit. No idea where they came from, but they were in a zip-lock mini bag. They appear to be 0.125" diameter or 3.02mm...my digital calipers get a bit confused...
I'll keep digging in my big box and hope to find some more.
Interested to learn that the screws on the white socket were captive. That socket has quite a small form factor, as of course has the brown one.
I haven't dismantled the white socket, but the brown one is easy to see inside as the top simply lifts off...and it looks very nice and clean in there and in good order.
I'm guessing 1950s for the brown one and 1960s for the white? Was the small white one designed to cover the small size of the old brown round pin sockets as an upgrade?
0.125" = 1/8 is a possible size for the likes of BSW/BSF, but generally smaller UK screws pre-metric would have been from the BA series.
Oddly enough they were metric, but not as we know it, and had a set of formulae to compute sizes of hex flats, etc, that did not result in "simple" sizes:
I long suspect that the choice of M3.5 used here for electrical work, and virtually unheard of in the EU, is down to them being close to 4BA.
0BA is almost M6, but most electrical stuff I have seen used 6BA or 4BA, occasionally 8BA (small, like M2) or 2BA (almost M5).
I have only once encountered an odd-numbered BA screw before (oh-er!) and that was for some 19" racks we had at my former work place. They were all from the 1940s/50s and had been adapted extensively (originally for a Muirhead-Jarvis "fax machine" used by publishers to send photographs between branches using the telephone lines) for our use as a photo-plotter
Some substantial cast aluminium things, with 1BA bolts so we still have some 1BA taps, a box of bolts, and the odd 1BA socket or nut driver around. Same really, racks went to the scrap yard ~4 years ago.
Reply to Pattress for old MK socket in the For Sale and Wanted Forum area at ElectriciansForums.net
Hi there, I am looking for some advice re: putting new sockets and usb sockets in my home. Someone will be rewiring the entire house but I have...
I have had three led strips installed under wall units as part of a kitchen refit. A new pattress box was fitted in a stud wall next to an...
Hi, I replaced an outdoor electrical socket recently with a 2 gang, BG socket which has LED lights to show when it is switched on. Since then I...
Wanted - Vintage Mk Electric Light Switch 4 Gang 2 Way - need of 3 these longer type of switches - 3 or 4 gang would be ok
