Not used lap db yet there chrome accessories are not to bad for the money but I personally only fit well known brands of db e.g hager,mk,Crabtree,dorman smith but if he was supplying it who cares it's all work and £ at the end of the day as long as all the circuits tested out ok and rcd tested out ok then there's no problem.only thing that put me of British General was I had 2 faults rcds in the same board when doing the x1 test was getting 400ms on both so won't use them again which is a pity cause that they were well put together for the £
Last BG board I used all RCDs and they all tested out virtually identical at x1 and x5, I was quite surprised at the consistency. However the last MK board I used, the pre-wired neutral links pulled out of the factory crimp and one of the RCDs wouldn't trip at all.
i know which brand I'll be using again and it won't start with M and end in K.
Phone Call Today
uksparks,
VoltzElectrical,
