Discuss PIR light L and L1 in the UK Electrical Forum area at ElectriciansForums.net
S
StffDhyn
Hi guys, i brought a new PIR bulkhead from homebase and its got a live an netual and a live 1 and earth. Can i use live 1 for a switch so i can override the light to stay on when the switch is flicked?
Dan
L1 might just be a link for an additional light. Lets have more info.
So the instruction manual makes no mention of this L1 terminal in either text or sketch.
usually L1 will be connected to the L side of the light. if so, it is to feed a 2nd light. if you feed a switched L to this via a switch, it should bring the light on manually. without seeing it, this is just an educated guess, so take the advice with caution. if in doubt, get an electrician in to sort it.
Call a local spark and you should have that light sorted for less than £30.00
If it's the one i am thinking of, yes the instructions are tat. I fitted one last year that a customer had supplied, very flimsy build and i was back within two months fitting a new one. Same as most cheap PIR's im afraid.
Reply to PIR light L and L1 in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Just a quick one, I want to use an ip rated light switch with a neon indicator to manually ovveride a PIR detector controlling an e27 LED...
Hi, Heavy industrial spark here, never do house bashing hence the question. I currently have a light switch at the front door not doing anything...
Hi there, I have an outside light that is turned on with a switch from inside and would like to change it to a PIR version incorporating an...
can anyone please advise on where the wires go? My electrician installed a new cable ready for when I bought a security light. The cable as shown...
