Search the forum,
Discuss PIR Lights in series in the UK Electrical Forum area at ElectriciansForums.net
H
highspark
Any reason why you can't put two PIR lights in series in close proximity?
Need to put 2 porch lights in each with a PIR. I wont come across any probs will I?
Do you have a shed? This is a good place to do experimentation.
Just a few questions
1/ What do you mean by placing them in series. Would that be lights in series or PIR sensors in series?
2/ Do you want the lights to operate together or separately?
3/ Are you planning to use the PIRs as switches as opposed to manually operated ones?
Reply to PIR Lights in series in the UK Electrical Forum area at ElectriciansForums.net
Hi, Heavy industrial spark here, never do house bashing hence the question. I currently have a light switch at the front door not doing anything...
Hello, Behind a tiny door in our under stairs cupboard we’d like to build a miniature room in which a little light would come on when the door...
I have a Security Light on my patio and until recently it worked fine. It stopped working and I couldn't decide if it was the LED Floodlight or...
Hi there, I have an outside light that is turned on with a switch from inside and would like to change it to a PIR version incorporating an...
Hi guys, Been asked to fit 2 lights and a switch, which in reality turned out to be rewiring a multiple PIR setup to a single switch, adding...
