Discuss PIR sensor for cars? in the UK Electrical Forum area at ElectriciansForums.net
A
alexg
Hi
Have you ever used a PIR sensor to detect cars - so that driveway lights come on automatically? Or would they be driving too slowly? Dont want to use photoelectric beams as they need big posts (customer doesnt !).
Cheers
:icon7:
No i haven't, but i cant see why not, go for it. They work on movement and proximity so speed shouldn't be an issue. Airports have a similar system that turns the taxiway lights on as the plane approaches, and then they go out once it has passed.
I installed one just inside some electric gates once pointing inwards and as the car rolls in, the driveway lights come on, they've never had a problem with it
Reply to PIR sensor for cars? in the UK Electrical Forum area at ElectriciansForums.net
Can I use multiple GU10 led lamps with their own PIR sensors in the same room? I have a row of existing lamps 600mm apart in a straight line & I...
Hi All, I need a bit of advice. My client is asking for a rather silly lighting setup in his bathroom and I am struggling to understand...
Hi there, I have an outside light that is turned on with a switch from inside and would like to change it to a PIR version incorporating an...
Hi all, Just a quick one, I want to use an ip rated light switch with a neon indicator to manually ovveride a PIR detector controlling an e27 LED...
