Discuss PIR's .....how far do you go...? in the Australia area at ElectriciansForums.net
P
p11jor
i got laughed at the other day when doing a PIR as i went up into the loft and noted that junction boxes were not screwed down, mentioned it to a few sparky mates and i got called the hitler of inspectors! how far do you guys go?
Personal opinion of workmanship does not come into PIR's IMO. You look at the job, and any defects must only be defects because they do not conform to regulations. Anything else is noted as recommendations on a covering letter. If the boxes not being fixed is against a reg, then note it on the cert. If not then note it on a separate letter if you wish.
Try reg 134.1.1 and 134.1.4
Reply to PIR's .....how far do you go...? in the Australia area at ElectriciansForums.net
So I have tried applying to every electrician mate/improver jobs there is on every job websites and I got a few calls saying that they want guys...
So a quick catch up so you can get an idea… I was asked to do a job for another electrician, as he is too busy. I’m busy myself but said I’d...
These are going to become the norm aren't they? I've been reading this...
I have completed Level 2, currently doing the 18th edition course, I wanted to know, what is it like to get myself into the commercial scene, I...
