I thought you were meant to fill the knock out boxes half full of plaster as well? :)
ugh I know what you mean
the last job i was on chasing down problems i found 4 boxes completely filled with plaster. spent quite a bit of time entertaining my apprentice with some very colourful language:cuss: :furious3: LOL.
That's when the lump hammer comes out liberally across the new plaster wall. Well you had to find your buried cables somehow.......
"plasterers , who needs them ?"
well anyone who doesnt fancy wall papering over bare brick :-D
plasterboard straight to brick then wall paper, job done
Reactions: 1 person
The plasterer on a job i'm doing at the moment came to price up last night at about 8pm, already up to a 12 hour day and he chirped up "not to question your workmanship pal but can you cut your cables back and tuck em into the back boxes so i can plaster them in.......
You can imagine my reply....
I don't understand why plasterers feel they have to do this, I certainly wouldn't employ one that did
i dont understand why we need to cut chases out deep enough to bury conduit for a house rewire ?
seems like alot of unnecessary work and mess when you can just chop back plaster and clip direct.
I hate the unnecessary work created when the plasterer trowels the cable and reduces the IR of it
i do mine about 30mm wide. thats a little bigger than my cold chisel lol.
clip down wall and job done (boss wont pay for conduit when we do houses, the work is just to keep us busy)
Surely it is the customer that is paying for the conduit or is you boss pulling a fast one the cost / time saving is probably negligible given that a conduit drop only needs a couple of clips or a snot or two of bonding to fix it compared to the effort to straighten and clip a couple of T&E's
Did a rewire for a relative a little while ago and very little chasing out was needed as most of the original wiring was in PVC conduit only needed chases where additional sockets were wanted put all the new cable in oval conduit
On a job a while back, had a building inspector pulled me up for not ccapping cables. wall was to be dry lined, dot&dab. asked him to read 7671 and come back with a reg. bloody hitler said it was their rules.
The other aspect is that customers are aware of what's available and what can be done , so most of them have seen capping or conduit of one form or another , I have been asked if I will be installing it most times when chasing walls out , usually there's some already in place on existing chases , so it doesn't look good when you install cables without this , I have gone down the route of round conduit as only my preference , because it makes it easier to replace cable , nearly every job I go to the customer wants to change things when the cables are in and this at least gives me a chance to pull in or remove as required
What about sockets within 350mm of corner lol Or does that apply onto new builds?
I tend to use conduit on all jobs on solid walls , wether it's new build or not , and even within the 150 mm of the corners , ps not sure where you get 350 mm from. LOL
It's from building regs not BS7671..something about sockets can not be sited within 350mm of corners.
I don't have a problem with their rules when they have made it clear when the job is priced what they want, the problem I do have is when they are being petty for being petty's sake some of these inspectors get a bee in their bonnet and make the rules up as they go along just to be a pain in the derrière
And what was the outcome in the end? Did the customer get the job signed off?
no idea. fell out with customer when he supplied 36 downlights and wanted to pay me £5 each to 2nd fix. i'd been paid for 1st fix, so i walked.
Reactions: 1 person
last jod I did I stripped all the cables ready and linked them up with Wago's but left them out of the DB,a large piece of cardboard pinned to wall with "WARNING ALL CABLES ENERGISED" and not a millimetre of plaster in any of my boxes when they'd plastered.
Reactions: 1 person
no idea. fell out with customer when he supplied 36 downlights and wanted to pay me 35 each to 2nd fix. i'd been paid for 1st fix, so i walked.
£35 each?
the only rewires we do are for clients on the cheap and to keep us busy, ive been boarding,mixing, second fixing etc recently and will probably have to paint the ******* soon as well.
telectrix
Mentor
Supporter
cheshire/staffordshire
Business Name
Telectrix
Plasterers, who needs them?
telectrix,
telectrix,
