Currently reading:
Plasterers, who needs them?
Discuss Plasterers, who needs them? in the UK Electrical Forum area at ElectriciansForums.net
telectrix
Mentor
as title. a bit od splodging in the gunge, done by yours truly:
I use a metabo chasing machine that cuts a chase 25mm wide and 25 mm deep , then remove the middle with a chisel in the multi drill , then install cables in 20mm round conduit with conduit just into the 20mm holes in metal boxes , plaster with one coat plaster and reskim and smooth of with trowel and water spray , , this leaves the conduit 5mm below surface , when I'm finished its ready for decoration ...
I find that anything less than 5mm may cause the plaster to crack if too thin in the future..
ideal method when you can do it. not recommended for a lived in house though. enough dust to fill a skip.
I do this in any house , I also attach a henry vac to the spout on the chase , the dust you get is when using the multi drill , but then you would get that anyway , still its a lot easier and cleaner than other ways I have tried , The chase machine has a spring loaded hood that sits flat on the wall so forms a good seal for the vacuum to work so its really clean . along with dust sheets as normal of course ...
I am doing a job at the moment so will post some pics later next week..
i dont understand why we need to cut chases out deep enough to bury conduit for a house rewire ?
seems like alot of unnecessary work and mess when you can just chop back plaster and clip direct.
i do mine about 30mm wide. thats a little bigger than my cold chisel lol.
clip down wall and job done (boss wont pay for conduit when we do houses, the work is just to keep us busy)
Because I was taught to use oval conduit in chases in existing walls by my mentor when I was an apprentice, and until I hear of a good reason not to I will carry on doing it this way.
I'm not condemning anyone who does it another way, or saying that my way is best, it's just the way I do things.
the main reason i use tube or capping is to facilitate rewiring of a drop if some muppet drills or nails it.
and how many times in say , the last 5 years , have you been called back to a domestic job you've rewired where a cable that is within the permitted zones , has been drilled through ?
im gonna guess its not often enough to justify automatically installing conduit on every job you do.........
my stepdad is an engineer but a thick one.
he starts drilling stud wall for a picture, he hits something solid so he pushes on harder till he has drilled through it (socket on other side of stud wall)
how he missed the cable i don't know
I thought you were meant to fill the knock out boxes half full of plaster as well? :)
ugh I know what you mean
the last job i was on chasing down problems i found 4 boxes completely filled with plaster. spent quite a bit of time entertaining my apprentice with some very colourful language:cuss: :furious3: LOL.
That's when the lump hammer comes out liberally across the new plaster wall. Well you had to find your buried cables somehow.......
The plasterer on a job i'm doing at the moment came to price up last night at about 8pm, already up to a 12 hour day and he chirped up "not to question your workmanship pal but can you cut your cables back and tuck em into the back boxes so i can plaster them in.......
You can imagine my reply....
I don't understand why plasterers feel they have to do this, I certainly wouldn't employ one that did
I hate the unnecessary work created when the plasterer trowels the cable and reduces the IR of it
Surely it is the customer that is paying for the conduit or is you boss pulling a fast one the cost / time saving is probably negligible given that a conduit drop only needs a couple of clips or a snot or two of bonding to fix it compared to the effort to straighten and clip a couple of T&E's
Did a rewire for a relative a little while ago and very little chasing out was needed as most of the original wiring was in PVC conduit only needed chases where additional sockets were wanted put all the new cable in oval conduit
On a job a while back, had a building inspector pulled me up for not ccapping cables. wall was to be dry lined, dot&dab. asked him to read 7671 and come back with a reg. bloody hitler said it was their rules.
The other aspect is that customers are aware of what's available and what can be done , so most of them have seen capping or conduit of one form or another , I have been asked if I will be installing it most times when chasing walls out , usually there's some already in place on existing chases , so it doesn't look good when you install cables without this , I have gone down the route of round conduit as only my preference , because it makes it easier to replace cable , nearly every job I go to the customer wants to change things when the cables are in and this at least gives me a chance to pull in or remove as required
I don't have a problem with their rules when they have made it clear when the job is priced what they want, the problem I do have is when they are being petty for being petty's sake some of these inspectors get a bee in their bonnet and make the rules up as they go along just to be a pain in the derrière
no idea. fell out with customer when he supplied 36 downlights and wanted to pay me £5 each to 2nd fix. i'd been paid for 1st fix, so i walked.
last jod I did I stripped all the cables ready and linked them up with Wago's but left them out of the DB,a large piece of cardboard pinned to wall with "WARNING ALL CABLES ENERGISED" and not a millimetre of plaster in any of my boxes when they'd plastered.
the only rewires we do are for clients on the cheap and to keep us busy, ive been boarding,mixing, second fixing etc recently and will probably have to paint the ******* soon as well.
Reply to Plasterers, who needs them? in the UK Electrical Forum area at ElectriciansForums.net
